Folder thumbnails won't refresh
guest1702
Post by guest1702 »
Refreshing thumbnails after changing from 1 to 4 or 4 to 1 image thumbnails in folder thumbnails has no effect. I have to delete the thumbnails from the cache in the options.
Re: Folder thumbnails won't refresh
guest1702 wrote:Refreshing thumbnails after changing from 1 to 4 or 4 to 1 image thumbnails in folder thumbnails has no effect. I have to delete the thumbnails from the cache in the options.
You should use 'rebuild thumbnails'
Dstruct
Post by Dstruct »
Still, there's a bug with refreshing folder thumbnails in 1.93.6!
When deleting the first image from a folder, XnView doesn't automatically refresh the folder thumbnail! I have to disable the cache as workaround :(
My preferences:
"Show 4 thumbnails in folder's ..." = disabled
"Auto refresh" (browser) = enabled
Dstruct
Post by Dstruct »
bump.
Dstruct
Post by Dstruct »
Dstruct wrote:Still, there's a bug with refreshing folder thumbnails in 1.93.6!
My preferences:
Still not fixed in 1.94! Makes the cache function useless for me :(
Dstruct
Post by Dstruct »
why doesn't xnview check if the files still exist?
