Custom Hotkeys / Shortcuts
Dreamer
Post by Dreamer »
Feature request - Custom Hotkeys / keyboard shortcuts (at least for some, most important features)
Re: Custom Hotkeys
Dreamer wrote:Feature request - Custom Hotkeys / keyboard shortcuts (at least for some, most important features)
ok, thanks for you suggestion ;-)
Lostclown
Post by Lostclown »
I second that request after having mentioned the same thing in another thread http://newsgroup.xnview.com/viewtopic.php?p=6427 and this thread being pointed out to me :)
Reagards, Lostclown
Xyzzy
Post by Xyzzy »
I support the idea, seems to be quite frequently requested!
X.
I wish key-remapping…
:) Hello !
- This request is related to that thread
- I would prefer also the space-bar like formerly for the “Next file”.
- So, I think that a feature / tool to remap the shortcuts keys could be very useful, like we have in Total Commander, for instance…
:mrgreen: Kind regards,
marsh
Post by marsh »
Perhaps keyboard mapping for just one key would be a good beginning.
One or twenty…
:arrow: marsh
:) Hello !
- Most certainly, but I guess that the basic codes to add could be the same as well for one key as for twenty…
graphix man
Post by graphix man »
customized hotkeys would kick ass!!!
Post by Guest »
graphix man wrote:customized hotkeys would kick ass!!!
:D I 100% quote this sentence!!!
Xyzzy
Post by Xyzzy »
Dreamer
Post by Dreamer »
Both links are already in Global Request & Suggestion list.
raducoc
Post by raducoc »
I support the idea.
And I think is werry useful to store the shortcuts configuration in one .INI file instead of registry.
Dreamer
Post by Dreamer »
raducoc wrote:I support the idea.
I agree, maybe in the xnview.ini, but it's not so important.
Dreamer
Post by Dreamer »
Try this as workaround, really great program - HotkeyP. You can assign any keyboard and mouse shortcut to any existing feature / action (hotkey, shortcut, menu item) - not only for XnView, but for almost any program.
Dreamer
riemenschneider
Post by riemenschneider »
I support fully customizable keyboard (+mouse) shortcuts! So many great applications offer that feature (for example openoffice.org) I'll prefer the settings to be stored in a separate file beause I think that many users would like to transfer their settings(file) to other existing XnView installations.
riemenschneider
