Change timestamp bug ?
Evds
Post by Evds »
"Change timestamp dialog"
From version 1.92.1 it is no longer possible to change the timestamp
of the "Exif: Date taken", "Exif: Date digitized" or "Exif: Date modified" parameter.
Works perfect in version 1.92.
ncruz
Post by ncruz »
I also found this bug... And it's a bit catastophic since it removes all exif information from the images...
ncruz wrote:I also found this bug... And it's a bit catastophic since it removes all exif information from the images...
Remove?????
And in 1.93.4?
Post by Guest »
I'm using 1.93.4, if I try to batch change exif time stamp all the photos get the EXIF information removed...
Anonymous wrote:I'm using 1.93.4, if I try to batch change exif time stamp all the photos get the EXIF information removed...
Could you try in 1.93.6?
