"Not enough memory" when converting WMF to JPG
instatnt
I can't convert from WMF to JPEG - program is saying "not enough memory" , I don't have options/Read/WMF/High resolution. I have latest version of XnView, any suggestions? please help
No Pb.
- It works for me under Win 98SE, with a *.WMF from Corel, and another from Windows…
- I used only "Save as…" from the View mode (main window).
Re: No Pb.
it's great, but not for me, I can't opened file and I don't have option save as... but thx,
Re: "Not enough memory" when converting WMF to JPG
Some questions which might help finding a solution:instatnt wrote:I can't convert from WMF to JPEG - program is saying "not enough memory" , I don't have options/Read/WMF/High resolution. I have latest version of XnView, any suggestions? please help
- How do you convert your image? Do you use Batch conversion or do you open the image and then save it?
- Does the problem occur with all your WMF images or just with a specific one?
- How much RAM (memory) does your computer have?
- Which Windows version are you using?
- Did you specify virtual memory? How much is available?
- Are you running other programs when doing the conversion?
- Perhaps you can run a SysInfo software which shows the memory usage
- What's the file size of your WMF file? Could you place it on a download server? (Another option is to send it to Pierre and/or me)
answers as follow:helmut wrote:- How do you convert your image? Do you use Batch conversion or do you open the image and then save it?
-i can't open full view of the image, i see only thumbnails, after choosing convert option and convert to jpeg - I have got message "not enough memory", i have no problems with other smaller files
-size of this file is 8274KB
-512MB
-windows 2000
-virtual memory initial size- 512MB maximum size 1024MB, available 8966MB
- no other programs are runing
- 8% of total memory use when perform the conversion, but still same message
thanks for help
Is it possible to download the WMF image?Anonymous wrote: -i can't open full view of the image, i see only thumbnails, after choising convert option and convert to jpeg - I have got message "not enough memory", i have no problems with other smaller files
-512MB
-windows 2000
- 8% of total memory use when perform the conversion, but stil same message
