I miss a fairly basic feature in XnView:
When you move around a selection I often need to move it in the X or Y axis only. In many programs you simply hold down Shift to accomplish this.
Can it be implemented in XnView? Any opinions on this?
Move selection in one direction only
+1 - I support this.
And also "Shift" for keeping ratio of the selection when resizing the selection, see topic Square selection with Ctrl or Shift.
Re: Move selection one direction only
Shift and? How to select the direction?Troken wrote:Hello,
Depending on the direction of mouse dragging either the horizontal or the vertical axis is fixed (if deltaY > deltaX then X=fixed else Y=fixed). Try it out in MS Word for example and you will see... (I guess also works in OpenOffice).xnview wrote:Shift and? How to select the direction?Troken wrote:Hello,
Exactly, it depends on how you drag the selection. Also an old feature in i.e. all Adobes software (moving selections or moving objects). Very handy and hard to do without.helmut wrote:Depending on the direction of mouse dragging either the horizontal or the vertical axis is fixed (if deltaY > deltaX then X=fixed). Try it out in MS Word for example and you will see... (I guess also works in OpenOffice).
