i have found a bit weird bug in reading and converting RAW/PEF from a Pentax K20D. The Thumbmail got all the right colours but if you get a preview, a view or a convertation of the PEF it got wrong Colours.
First i thought about a Camera Failure, but after Converting the PEF with the Pentax own converter i got the normal Colours.
I made a view examples, a screenshot and an jpg of the correct convertet jpg and you can find it there :
http://www.flickr.com/photos/9420103@N03/?saved=1
I hope this could help you, if needed it will be no probem to send
you the original RAW/PEF File.
regards from cologne
vaginux
