xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=12886]Transparency & alpha[/url]) wrote:I think that it will be good to move the 'Use transparency & alpha' from option/view to menu view
“Use checkerboard pattern as background” in menu and toolbar
- Forum Librarian
I would like to suggest that the Use checkerboard pattern as background option be moved to the View menu, and also that it be made available as a command for customizing the toolbar.
Re: “Use checkerboard pattern as background” in menu and too
Is toggling this setting really used that often? If so, it should really have an own menu item and a toolbar button.XnTriq wrote:I would like to suggest that the Use checkerboard pattern as background option be moved to the View menu, and also that it be made available as a command for customizing the toolbar. ...
White or C.P. ?
• I miss that command as a button, especially. Very often, I've to change in the Options, that's not handy…
- For instance, I need to view how a current image having transparency looks really on a solid background,
or if it has a white BG (I use it sometimes for icons sources as BMPs), and it's difficult to distinguish
the chequered pattern from pure white with small images.
• Hence, I support. And indeed, a short-cut, to be consistent.
- Lack of the COMMANDS MANAGER still…
