EXIF date
nikon
EXIF date
Post by nikon »
Begining with ACR v4.4 the EXIF time taken is always 00:00:00 (hour), but reading the exif with any other program than xnview, everythig is ok.
Re: EXIF date
nikon wrote:Begining with ACR v4.4 the EXIF time taken is always 00:00:00 (hour), but reading the exif with any other program than xnview, everythig is ok.
Could you send me a file?
nikon
jpg
Post by nikon »
send file by mail,
Thanks for your efforts Pierre
Re: jpg
nikon wrote:send file by mail,
at xnview.com?
nikon
exif
Post by nikon »
No, at "pierre.g" the mail at you profile (MSN Messenger).
Re: exif
no please webmaster at xnview dot com
nikon
exif time
Post by nikon »
there is an error of ACR 4.4...
EXIF Time Stamp Error: There is an error in the EXIF time stamp update technology that causes Lightroom to believe that the files are out of sync with the correct time stamp as displayed in Lightroom. Any ensuing metadata update will attempt to incorrectly modify the EXIF time stamp in the original raw file itself. This is the only metadata field that Lightroom will write to an original proprietary raw file. This error will not impact the integrity of your image data. The Camera Raw plug-in also will incorrectly change the EXIF time stamp in files converted by the plug-in. The information written to the XMP sidecar files or XMP metadata in the converted files will remain correct.
the other program that i use (showexif) read the correct time, but the 'normal' viewers not
Sorry... :(
And thanks for this FANTASTIC program
