Display Multiple Image in Fullscreen
Boo025
Post by Boo025 »
Currently (1.91.6) when you go into fullscreen mode it only shows the single picture.
Is it possible to modify such ways that you can have more than 1 image displayed in fullscreen mode at same time?
Re: Display Multiple Image in Fullscreen
Boo025 wrote:Currently (1.91.6) when you go into fullscreen mode it only shows the single picture.
Something similar to Compare?
Like strip¦comics
:arrow: Pierre
:) Hello !
• I think that Boo025 means something like a strip of image¦comic-like view.
• Select several images, when asking for "Full screen", then :
- Build a temporary strip¦comic-like image in order to fill the screen,
- Display the temporary strip¦comic-like in full screen…
- Delete the temp. image when "Full screen" is closed.
:mrgreen: KR
Boo025
Post by Boo025 »
Here's an example of what I'm trying to describe.
Let's say there are 9 images named: 1.jpg, 2.jpg, ..., and 9.jpg.
Currently, when you go into fullscreen mode to view these image, it only shows 1 image at a time.
So, first it will show 1.jpg, then next will be 2.jpg, and so on.
What I'm trying to describe is that instead of displaying 1 at a time, have an option that allows you to display 2 or more image at same time.
So, in fullscreen mode, it will show 1.jpg & 2.jpg, then next will be 3.jpg & 4.jpg, and so on.
Here's picture showing how it should look. The top image represent current method and bottom image represent the new method to view multiple image.
http://img27.picoodle.com/img/img27/4/3 ... aebe62.png
My rationale behind this idea is because alot of people have 16:9 monitors or dual monitors (10:4, 32:9 etc.) So the extra space can be used to display multiple pictures at once.
Ok, already requested to read comic books
