Resize picture to a fixed cm-value
Peter2
Post by Peter2 »
I have some screenshots (PNG), and I want to insert them in a table in Word, which is 12 cm wide.
So I have to "resize all PNG which are wider than 12 cm to a wide of 12 cm and keep the proportion width / height".
What I have to do?
Peter
Peter2
Re: Resize picture to a fixed cm-value
Post by Peter2 »
Peter2 wrote:...What I have to do?
Peter
Nobody knows?
Peter
Arqfaim
Post by Arqfaim »
Use the resize tool (Shift-S). Change the values of Print Size fields.
If you have other other basic doubts select from menu Info>Help and use the search field (e.g. resize).
Peter2
Post by Peter2 »
Arqfaim wrote:Use the resize tool (Shift-S). C...
OK - I found it in the commands for a single image. But how can I make it in batch-mode?
Peter
currently in batch resize, you can only use pixels
