HI all
First I apologise up front if this is a dumb question as it appears when I asked it at IrfanView the response was that I must be joking - well I'm not - I just want to know if it is possible, if it isn't then fine but I always believe if you do not ask you do not get (an answer one way or the other), so here it is...
Is it possible for XnView to open INDD InDesign files?- if not fine, but if it could then great - simple question.
If it cannot does anyone know of another program that will - only need read only so open to any constructive comments please
Cheers
Indesign file format view?
Hello gwmbox,
I assume it's no big deal for Pierre to enable XnView to read the embedded thumbnails of InDesign documents. But when it comes to opening the document itself, the situation is similar as with Corel's proprietary file formats.
WinPlanet ([url=http://cws.internet.com/article/2890-.htm]Adobe's Creative Suite CS2 Hits the Shelves[/url] » Adobe Bridge CS2) wrote:Bridge will display thumbnails for any of Adobe's files that include embedded thumbnails. In short, that means you can more easily identify your PDF, Illustrator, Photoshop, and InDesign files without having to first open them.
Extensis (Portfolio 8.1.1 Release Notes » [url=http://dl.extensis.com/downloads/PF/EN/P/PortfolioServer8.1.1-8.1.htm#whatsnew]What's new[/url]) wrote:InDesign CS2 filter
Portfolio 8.1.1 can now preview Adobe InDesign CS2 documents that contain embedded preview images. To enable this feature, in the InDesign Preferences dialog box, in the File Handling area, enable the “Always Save Preview Images with Documents” option and choose a preview size. When InDesign files are added to a Portfolio catalog, the first page of your document will be used for the document's thumbnail and preview image.
iView Multimedia (Tutorial: Improving Thumbnail Quality » [url=http://www.iview-multimedia.com/tutorials/thumbs/indesign.html]Adobe InDesign[/url]) wrote: By default, iView makes Bitmap PICT thumbnails at 128x128 pixels of the first page of InDesign documents. This is an example of an InDesign thumbnail of the iView user manual:iView renders only the thumbnail Media view. iView’s Rebuild Thumbnail command will not improve the quality of InDesign thumbnails.
Softfields Technologies ([url=http://www.softfields.com/index.php]News[/url]) wrote:Published ST Thumbnails Explorer v1.2.2220
Adobe Illustrator AI/AIT CS3 and Adobe InDesign CS+ support has been added.
Re: Indesign file format view?
Could you send me some samples, please?gwmbox wrote: Is it possible for XnView to open INDD InDesign files?- if not fine, but if it could then great - simple question.
xnview wrote:Could you send me some samples, please?
- Google Searches for...
- INDD = InDesign Document
INDT = InDesign Template
INX = InDesign Interchange
