"mapi not installed in your system" when emailing
pjallittle
Post by pjallittle »
Mine works fine but a friend has Comcast. When he tries to email from Xnview, he gets the following message:
Any ideas how he can get around this? Or is it an email program problem.
Re: emailing from Xnview
XnView need MAPI interface to send email, perhaps this client has not it
pjallittle
Thank you, but that's obvious, the question is, how does one obtain MAPI?
oops66
Post by oops66 »
pjallittle wrote:Thank you, but that's obvious, the question is, how does one obtain MAPI?
You have probably to install a new e-mail soft. like Thunderbird or Outlook-express, or ..... to have this Mapi file installed.
http://newsgroup.xnview.com/viewtopic.p ... light=mapi
FYI:you can use this xnview search link too:
http://newsgroup.xnview.com/search.php
pic_viewer
Re: "mapi not installed in your system" when email
Post by pic_viewer »
pjallittle wrote:Mine works fine but a friend has Comcast. When he tries to email from Xnview, he gets the following message:
I use Thunderbird latest version and have the same problem. I can easily use other programs, they will start TB and I get a blank message send edit window with the correct attachement.
I don't understand why XnView has it's own Message edit window - what is that good for? Maybe the problem is that XnView can't transfer all those data to the mail client then, as can be read here:
http://kb.mozillazine.org/MAPI_Support
Just sending the pic(s) instead might work...
yakk
I found a solution:
Post by yakk »
go to win.ini file and add
[Mail]
MAPI=1
