Right Click Drag/Drop on Files
tannim
Post by tannim »
Hello, this is a basic file management suggestion, not relating to image viewing at all.
Is it possible to include a Right click drag and drop of files and folders? It would allow a menu to pop up when you let go at the destination(like Explorer) that gives the options of Copy, Move, Create Shortcut, or Cancel.
Example: you browse over to C:\picture\ and select a picture called b.jpg. You want to keep b.jpg there but want a shortcut on your desktop. Right click and drag to the desktop, left go and choose Create Shortcut.
It would allow easier copying and pasting. I know there are other methods, but this is a very quick way of doing it and being sure exactly what files you are copying or moving or whatever.
This is very helpful for picture and file maintainance
Dreamer
Post by Dreamer »
I think it was already suggested, but I can't find it.
Anyway, I support it.
Dreamer
