Mouse Copy/move/delete Folders in Tree Pane
tannim
Post by tannim »
Is it possible to allow folders in the tree pane to be moved with left mouse button clicking/dragging.
Select it like normal but instead of letting go, drag the folder somewhere else and drop it into a new directory to move it. I know I can right click and rename or delete. Those are helpful, but the dragging is much more effecient to me for moving or copying if you allow right mouse button dragging.
Dirk13
Post by Dirk13 »
Cross reference to the same question:
http://newsgroup.xnview.com/viewtopic.php?p=61604
