Rating Hotkeys
andrewj
Rating Hotkeys
Post by andrewj »
Hi, I have two questions about ratings (and tags):
1. Where are the ratings and tags stored. Do they update the file?
2. Are there any alternative hotkeys for ratings? I'm working on a laptop and the numeric keypad keys are almost completely inaccesible. Can we also make the normal number keys work the same way?
Thanks
Andrew :?
Re: Rating Hotkeys
andrewj wrote:1. Where are the ratings and tags stored. Do they update the file?
In a database (xnview.db)
Ok
andrewj
Post by andrewj »
Dear Pierre,
Thanks, that would be great. Please make sure they will work in full-screen mode as well as browsing.
Andrew
andrewj
Post by andrewj »
Hi Pierre,
Did you manage to make these changes for 1.93.6, which I see you've just released, or are they on your "to do" list, which I'm sure is very long...
No problem if not, I'd just like to check.
Thanks
Andrew :)
andrewj
Re: Rating Hotkeys
Post by andrewj »
Dear Pierre,
Any chance of getting ratings working with the normal 123 keys soon?
Many thanks,
Andrew
