Don't start Windows Image Acquisition (WIA) Service (DONE)
Dstruct
Post by Dstruct »
Why does XnView always start the "Windows Image Acquisition (WIA) Service"? Which functions of XnView need this service? If it's really needed, wouldn't it make much more sense to start it just when really needed instead of starting it always?
DONE (problem can't get solved as caused by Windows Explorer)
When no device…
:arrow: Dstruct
:) Hello !
• A long while ago, I groused already about the active entries for TWAIN and WIA in the File Menu at start-up
(no file loaded), while I have not any device like a scanner or a camera or the like installed here…
- That could be checked prior, there are indications in Win, I guess.
- Thus, these entries might be greyed in the case, and the service not started, you are right.
- Hence, I support your request !
:mrgreen: KR
ouistiti
Post by ouistiti »
:arrow: Dstruct
I support too !
Paul
1,77245385090552...
Dstruct
Re: When no device…
Post by Dstruct »
Clo wrote:I have not any device like a scanner or a camera or the like installed here
Same here. That's why I'm asking :)
Re: When no device…
The WIA entry is greyed if i have no WIA device
Dstruct
Re: When no device…
Post by Dstruct »
xnview wrote:The WIA entry is greyed if i have no WIA device
Not here.
I just can say that I had a Canon EOS 350D camera installed via USB some days ago. But I've uninstalled all software and drivers of it. In the control panel I don't see any devices, so ...
Re: When no device…
Do you have Xp?
Dstruct
Post by Dstruct »
Yes, XP Professional SP3.
Driver, no device ?
:arrow: Pierre
:) Hello !
• Nothing is greyed here either :
• Maybe that occurs when an old driver is still installed, while there is no device at all ?
- It should be needed to check for the device, not the driver only…
:mrgreen: KR
pic_viewer
Re: Driver, no device ?
Post by pic_viewer »
I tried the WIA services from within XnView and don't see why I ever should use them. Therefore I would like to disable this although I do have a scanner and a Digicam.
Dstruct
Post by Dstruct »
Just installed a new machine with fresh Windows XP SP3 and XnView still starts the Windows Image Acquisition (WIA) Service. No camera or scanner were attached/installed to the system!
I've just tried on a fresh install, and the menu is greyed :-(
Dstruct
Post by Dstruct »
xnview wrote:I've just tried on a fresh install, and the menu is greyed :-(
which os?
also i never looked at the menu. i always look at the event-viewer. there you can see that the service gets started with xnview ...
Let guess…
:arrow: Dstruct
:) Hello !
You wrote
which os?
• I'ld bet that Pierre is using his beloved Win 2K still… ;)
- Here, with Win XP-Pro SP1 (En-Fr), the menu entries and the services are "ON"… :|
:mrgreen: KR
which os?
Xp
