Delete allfiles with same name even with different extension
mormax
Post by mormax »
I've noticed, that latest version of XnView (not tested with older ones) deletes two files of the same name, even if the extension is different. It happens with .cr2 and .jpg files - when I have in the directory 2 files with the same name, and want to delete one of them - XnView deletes both.
Kind regards
Re: Delete allfiles with same name even with different exten
It's companion files option/general/For copy/move/delete use companion file
mormax
Post by mormax »
Thank you for quick response.
Next time, I'll take a better look at the option settings :wink:
Kind regards,
Rafal
