--> Just remains from MP Lin*x Version alfa0.005:
http://newsgroup.xnview.com/viewtopic.php?t=15263
0.005_2-) video code on linux MP, postponed
0.005_6'-)The possibility to also change the definition texture quality as options in a next version for high quality zoom.
New bugs or requests:
0.015_0-) Sometime my system freeze about 5 seconds (and in this case, i have a high CPU system activity 60% + user40% and the memory cache is high too) when I browse in a large thumbnails windows with many files or when i try to resize the layout windows...
(Usually CPU system activity stay at ~0%)
...But i think this bug come from QT4 core system management under Linux, not from the XnView-MP-unix-alfa.015 binary , because I have not this kind of problem with XnView-MP-Win-alfa.015 under Wine & Ubuntu, but ???
0.015_1-) With transparent png (32 bits) files , if I change the zoom level, the colors are not good (it's ok only if zoom = 100%)(in 16 bits config. screen display but maybe also with 24 ?).
Problem only with high quality zoom ON (reduce&enlarge or enlarge or reduce, not with never)
0.015_2) I can not keep the thumbnails window size (layout adjustment resizing), custom layout not saved in the next xnview start.
0.015_3-) ((...)) to hide some fields (or customs labels) does not work.
like here: http://newsgroup.xnview.com/viewtopic.p ... highlight=
0.015_4-) If in the configuration, under options/integration/ "folder used for other files" is set to "XnView", the thumbnails cache is not created if the exactly directory XnView name does not exist (example XnViewMP directory name)
Fortunately this works with the "custom" setting directory.
For the "save setting" "as ini file in folder" "XnView", that works because I guess it is related to the current xnview binary file, it should have the same behavior for "folder used for other files".
v.015 Lin*x version_bugs&requests
oops66
oops66
Re: v.015 Lin*x version_bugs&requests
0.015_2) ... custom layout not saved in the next xnview start. - half done
Solved into the MP Version 0.1, thanks Pierre
continues here:
http://newsgroup.xnview.com/viewtopic.php?p=67427#67427
continues here:
