Toolbar: "Reset all" and initial default differ
After installing and starting, XnView shows the default toolbar with its toolbar buttons. When using "Reset all" in Tools > Options > Interface > Toolbar, all toolbars are supposed to be reset to their initial default state, but there are some differences:
Image view mode:
Flip vertical
Flip horizontal
Frame > Goto page
Properties
Browser mode:
Scan
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=60380#60380]Toolbar presets[/url]) wrote:
XnTriq wrote:
  1. Make a fresh install (clean INI) of XnView from a ZIP package (XnView-win-small.zip or XnView-win.zip or XnView-win-full.zip).
  2. Start XnView and choose “application folder” as “location for program settings” in the Configuration wizard.
  3. Go to Tools » Options... » Interface » Toolbar » Buttons » Buttons displayed.
  4. Click the Default toolbar button.
    » 3 buttons are added to the Basic toolbar. :bug:
Yes right
Ooops, didn't expect that this has been found, already. Perhaps I should use the forum search. ;-)
Locked topic.
