by darrask » Sun Jan 18, 2009 1:52 am
I want to suggest something I did not notice before:
ICC profile, if different from sRGB, is kept ONLY if the ICC convert transformation is applied, and the input and output fields are let BLANK, which is counterintuitive!
I mean... wouldn't it be better to make ICC preservation the default behavior so that we add the ICC conversion transformation only if we really want to convert from one profile to another?
If someone uses some different filter than sRGB, he will probably always want his ICC profile to be kept when he converts his pictures, and only-sRGB users shouldn't care to have that feature permanently enabled.
Or at least have that feature enabled by default for users who chose to have ICC management enabled in the general preferences (would be most logical).
what do you think? Am I the only one to have this?
