There is a problem with creating an exe/scr slideshow at fixed size.
The size of the image is what is entered, but the FRAME XnView puts around the show makes the area larger than the desired result.
I suggest that you offer a "frameless" option for creating such slide shows.
At the very least, I suggest that you make the frame the size entered into the "fixed size" dialog.
Thanks for your consideration.
create exe/scr - frameless
fbachofner
Dreamer
I think it's OK, if you have the pictures with size 1024x768, then all the pictures would be resized to a smaller size. Moreover, the frame is not the same on all operating systems (XP/Vista). So the size should be the size of the image IMO.
I agree with a "frameless" option, it's possible, because it was working so in the beta version, it was a bug.
Dreamer
Dreamer
Dreamer
