Fullscreen mode instead windowed mode without f11 pressing
How to use XnView. Post your question or ask for help, here.
Moderators: helmut, Olivier_G, Dreamer, XnTriq, xnview
Postby Lubos » Fri Jul 25, 2008 4:57 pm
Can I set fullscreen mode as primary mode instead of windowed mode, without pressing F11? I stopped using ACDSEE and this is problem for me, I don't need window mode (maybe as secondary for seldom using). And further - why is necessary to press Enter 2x to return from fullscreen mode - first to window, second to browser - I'd like to return directly to browser. I think that this all was possible in some very old version.
Lubos
Re: Fullscreen mode instead windowed mode without f11 pressi
Postby Dreamer » Fri Jul 25, 2008 11:57 pm
It's still possible in the latest version, try these options:
Options > General > Operations > Mode when starting with a file > Fullscreen Browser
Options > General > Keyboard/Mouse > Switching modes > Use Enter.. > Browser <> Fullscreen | Viewer <> Fullscreen
However, it will be the 'browser' fullscreen, some features are not available there (crop for example) - more here.
Option "Browser <> Fullscreen Edit | Viewer <> Fullscreen Edit" would help you probably.
Dreamer
Dreamer
Moderator
Postby Lubos » Sat Jul 26, 2008 4:19 am
Thank you Dreamer, it's OK now...
Lubos
Postby Dreamer » Sat Jul 26, 2008 10:59 pm
You're welcome.
Dreamer
Dreamer
Moderator
Postby Guest » Wed Nov 12, 2008 8:18 pm
I'm also having some problems with the viewer / fullscreen...
I have set xnview so that I switch between browser and fullscreen with enter-key. Works fine until I select multiple files and hit 'enter'. Then it jumps to viewer mode. Is this intended behaviour? And if it is can I chance it?
Postby Dreamer » Thu Nov 13, 2008 12:08 am
Anonymous wrote:I have set xnview so that I switch between browser and fullscreen with enter-key. Works fine until I select multiple files and hit 'enter'. Then it jumps to viewer mode. Is this intended behaviour? And if it is can I chance it?
Looks like a bug.
Dreamer
Dreamer
Moderator
Postby xnview » Fri Jan 09, 2009 10:59 am
Please try XnView 1.96 beta
Postby Dreamer » Fri Jan 09, 2009 5:23 pm
Looks like a bug.
This bug has been fixed in the latest beta version.
Dreamer
Dreamer
Moderator
Postby ckv » Fri Jan 09, 2009 10:48 pm
Dreamer wrote:This bug has been fixed in the latest beta version.
Confirmed the original bug is fixed, but the fullscreen viewing is not restricted to the selected files only (as it probably should be), all files in the current folder can be viewed.
ckv
Postby xnview » Mon Jan 12, 2009 9:36 am
It was like that in 1.95?
Postby ckv » Mon Jan 12, 2009 12:58 pm
xnview wrote:It was like that in 1.95?
No. I guess the "browser fullscreen" doesn't support viewing the restricted selection. It's fine with me. :)
ckv
Postby xnview » Mon Jan 12, 2009 1:01 pm
No, you means that 1.95 & 1.96 has the same behavior?
Postby ckv » Mon Jan 12, 2009 1:16 pm
xnview wrote:No, you means that 1.95 & 1.96 has the same behavior?
Well 1.95 obviously has this bug with Switching modes, but when using F11 the behavior is the same in 1.95 & 1.96.
ckv
Re: Fullscreen mode instead windowed mode without f11 pressing
Postby circ » Sun Sep 20, 2009 10:59 am
I was missing the ability to switch directly to fullscreen viewer until I found the solution here. However, it does bypass your selection when you switch the behaviour to this, and I for one miss this.
circ
Return to General Support
Who is online
Users browsing this forum: No registered users and 4 guests
