1.94.1 - no IPTC Display in Browser-Tooltip
Peter2
Post by Peter2 »
I have a TIF-File where I added IPTC-Infos and I defined in "Configuration - Browser - Show Tooltip" and in "Fullscreen - Show Information" these lines:
EDIT: I pasted here the definitions from trhe INI-File, because it is not possible to paste and display the original definitions.
TooltipText=<Filename>||Allgemein <IPTC>; <IPTC>; <IPTC>||Copyright <IPTC>; <IPTC>; <IPTC>||Status <IPTC>||This is only a simple, stupid, long text to show that the display-information overrides the picture.
The result:
- I can see the IPTC-data in the "properties - pane"
- I can not see it in the tooltips. Only filename and fixtext is displayed, but no IPTC.
- I could see it in Fullscreen after first cofiguration, but after programm restart it is gone and display the same as in tolltips: Filename and fixtext
Bug or maloperation of the user?
Peter
Re: 1.94.1 - no IPTC Display in Browser-Tooltip
could you send me the file?
Peter2
Post by Peter2 »
xnview wrote:could you send me the file?
I sent you a mail.
Peter
Peter2
Post by Peter2 »
Peter2 wrote:...The result:
- I could see it in Fullscreen after first cofiguration, but after programm restart it is gone and display the same as in tolltips: Filename and fixtext...
1.8.2008, Version 1.94.2:
Bug fixed for fullscreen, but not for tooltips in browser-mode.
Peter
