White background when converting PNG to JPG with nconvert?
Rajko Aust
Post by Rajko Aust »
Hi
What is the correct nconvert command line parameter to convert a 32bit PNG with Alpha to a JPEG, so that the Alpha channel is merged but the background is not black (as recent)?
in XnView it works when converting 32bit PNG to 24bit the background is set to white, but not in nconvert :(
thanks for your help
Rajko
Rajko Aust
This one DON'T work, why?
-bgcolor 255 255 255 -canvas 100% 100% center
Use -transpcolor 255 255 255 -merge_alpha
Rajko Aust
Thank you, that saved me a lot of time!
