Hi
I (erroneously) added an IPTC Keyword to 470 images, and I am now unable to erase it.
Here is how I proceed :
- select the images
- choose CTRL+I (IPTC edit) / Keywords
- erase the keyword value (select the value in upper area + erase button)
- select Replace all previous values
- clic Write All
The keyword are still there after this... Am I doing something wrong ? If this is a bug, is there another way to remove this keyword ?
Thanks for your help ! (I am using v1.94.2 Aug 08, French)
And thanks for XnView, too !
Can't change IPTC Keyword field
roelleke
Re: Can't change IPTC Keyword field
You want to remove one keyword, but files can have some other keywords, right?
oops66
--> Patrick75002 & roelleke:roelleke wrote:Hello,
I have the same problem when I selected "update or change XMP data".
If it is unselected it is possible to change the IPTC Data but the XMP Date ist still old.
The the funktion "Edit > Metatada > Rebuild XMP" rebuilds the IPTC Data and not the XMP Data.
Dieter
On which OS ?
Because, I have also a similar problem when I select "update or change XMP data" into the IPTC menu (crtl+i) on v1.94.2.
see here:
http://newsgroup.xnview.com/viewtopic.php?t=15773
roelleke
roelleke
roelleke
I mean this Step by Step.
- Edit IPTC Data (change one Field - > Value 1)
- build XMP Data with "Rebuild XMP" or with "Update or create XMP" in the "Edit IPTC" dialog
- Edit the IPTC Data again (change one Field -> Value 2)
- now choose "Rebuild XMP"
- Edit IPTC Data an you will see the the field that you edit contains Value 1 and not Value 2.
When XMP Data exists and you have choosen "Update or create XMP" in the "Edit IPTC" it is not possible to store any changes of the IPTC Data in a not empty field. The same effekt you will see when you haven't choosen "Update or create XMP" but you try to use "Rebuild XMP Data" .
I hope this description is detailed enough.
oops66
--> roelleke and Pierre
FI: I have exactly the same problem (French post here).
http://newsgroup.xnview.com/viewtopic.php?t=15990
oops66
Fixed for me in 1.95 beta 3
http://newsgroup.xnview.com/viewtopic.php?t=15976
