48 bit TIFFs reading/writing
PSHRutPark
Post by PSHRutPark »
I have 48 bit TIFFs file generated by a panorama stitching programme.
XnView clearly shows, correctly, the number of bits as 48 in the Properties Pane, the bottom status bar and in the"hover tool tip" above thumbnail.
However, when the TIFF is viewed then the bottom status bar shows 24bit and if the image is saved then it becomes 24 bit.
Is this an error and/or how can the saved tiff be retained as 48 bit?
Thanks
PETER
Re: 48 bit TIFFs reading/writing
XnView load pictures as 24bits
PSHRutPark
xnview wrote:XnView load pictures as 24bits
OK. Thanks Pierre
oops66
Post by oops66 »
Maybe you can try: IRIS (free with FITS 48 bits support)
...Since version 5.53 now supports the 48-bit FITS format (true color, 3 x 16 bits), as well for input and output. The functionality available in the PIC format proprietary PIC are also now available with the FITS. The PIC format retains some an advantage in terms of disk loading and saving speed ...
http://newsgroup.xnview.com/viewtopic.php?p=65090#65090
XnViewMP Linux X64 - Debian - X64
PSHRutPark
oops66 wrote:Maybe you can try: IRIS (free with FITS 48 bits support)
Thanks.
IRIS worked a treat. I have 48 bit TIFF panoramas which wont load into Nikon Capture NX.
The solution is to load the 48 bit TIFF into Iris and then save it again, as a 48bit TIFF. The image now loads into Capture NX!
Your suggestion resolved a chronic "missing link" in my work flow.
PETER
oops66
8/16/32 bits per component reading/writing support
Post by oops66 »
You're welcome, see here too (xnviewMP)...
http://newsgroup.xnview.com/viewtopic.p ... 96#p111296
