1.94.2: Gamma textbox disabled
DarkBlood__ARGentina
Post by DarkBlood__ARGentina »
(XNVIEW 1.94.2 BUG) gamma textbox disable.
Options > Browser > Thumbnails > Use Gamma Correction (DISABLED):
Options > View > Use Gamma Correction (DISABLED):
thanks Pierre, can you activate my already registered username "DarkBlood"?
link to my username :(
http://newsgroup.xnview.com/profile.php ... ile&u=5851
Re: 1.94.2: Gamma textbox disabled
DarkBlood__ARGentina wrote:... thanks Pierre, can you activate my already registered username "DarkBlood"?
Your user is active, now. You should have received an email with a new password. Place a short note here if you still have problems.
DarkBlood
Post by DarkBlood »
no problems :D
THANK YOU helmut!!!! (k)
