Use XnView with several users on different computers
Fraenzken
Post by Fraenzken »
I've used XnView for my pictures for quite a time now and like the way it works (and its speed!) a lot. Now I wonder if it's possible to use XnView with pictures on network drives so that e.g. User A defines a category to collect some pictures and User B opens XnView on another computer and finds this new category with the pictures User A put in it?
Best wishes!
Frank
Re: Use XnView with several users on different computers
Fraenzken wrote:Hi,
Yes it's possible if the network drive is the same for all users
Fraenzken
Post by Fraenzken »
That's the case, Pierre.
So how do you do it? Is there a way of telling XnView which path to use for the database?
Fraenzken wrote:That's the case, Pierre.
Yes, in system integration & thumbnail/Cache
Post by Guest »
Thanks Pierre, I'll try it!
Frank
JohnFredC
Post by JohnFredC »
But won't there be locking issues for simultaneous users of the db?
I think SQLite requires database (not record, not table) locking for any writes...
John
xnview wrote:... Yes, in system integration & thumbnail/Cache
This settings is for categories? I thought this setting was for the location of the thumbnail cache, only?
Post by Guest »
JohnFredC wrote:But won't there be locking issues for simultaneous users of the db?
I've tried - it seems to lock the database so if two users work with XnView the same time one of them doesn't have any access to the categories. Still it's better than nothing :-)
Frank
