DCT Float in JPEG, Who use this?
RGBA
Post by RGBA »
I just wanted to ask you, did you ever used the floating-point DCT method?
The following differences are just compared between DCT float and DCT int (slow) method.
Pro:
- more accurate (depend on CPU)
- the difference should be not visible
- lower size
Re: DCT Float in JPEG, Who use this?
RGBA wrote: The following differences are just compared between DCT float and DCT int (slow) method.
You means DCT float (slow) :-)
RGBA
Post by RGBA »
There is only one float mode, so why should I add slow? :?
If you relate to the Streaming SIMD Extensions (SSE),
the common Applications (for example XnView) support just the one.
