-rmeta reduces quality ?
xenry
Post by xenry »
hello and thanks for the wonderful xnview =)
I am trying to write a simple program that uses nconvert to remove jpeg metadata (exif and so on). So I call nconvert with:
nconvert.exe -rmeta [filename]
all works fine, the metadata is removed, but the jpeg file is a lot smaller ( as filesize ), about 2-3 times. I was wondering whether after the metadata removal the jpeg is resaved with lower quality? Any suggestions will be appreciated. Thanks in advance =)
Re: -rmeta reduces quality ?
Yes currently -rmeta doesn't work like clean in xnview, the picture is saved again
xenry
Post by xenry »
thanks for the answer
so is there any way to access xnview->edit->metadata->remove all metadata externally? or any other workaround for removing metadata without losing quality ?
I'll add such option in next version
xenry
Post by xenry »
thanks for the great support !
DOS386
Post by DOS386 »
xnview wrote:I'll add such option in next version
      -jpegtrans op     : JPEG lossless transformations
              rot90  : Rotate 90 degrees
              rot180 : Rotate 180 degrees
              rot270 : Rotate 270 degrees
              exif   : Use orientation EXIF tag
              vflip  : Flip vertical
              hflip  : Flip horizontal
          -jpegcrop x y w h : JPEG lossless crop
          -rmeta  : Remove Metadata (EXIF/IPTC/...)
The bottom line is not yet lossless in 5.00 ...
dadaniel
Post by dadaniel »
And it's still not lossless :(
