In using v.1.93.6 and having just installed v.1.94.2, I am unable to obtain thumbnail sizes greater than 192x144. When I select 384x288 for example, the area on the screen for the thumbnail increases, but the actual photo image size does not. (I am able to decrease the size of thumbnails however). Is there a setting I need to change to obtain larger thumbnail images?
Thanks.
Brett
Thumbnails larger than 192x144?
It's there !
• Options (F12) >> Thumb nail >> ----Appearance---- >> [×] Use huge thumb nails
might do the trick… and disable the embedded thumb nail display : [ ] Use embedded Thumb nail.
bbrogan
Thanks Clo -
I was just reading up on Cache and found my answer indirectly in another way also (or maybe its doing the same thing as you suggested). By selecting the sub-option "Create thumbnail from original image if embedded is smaller than thumbnail size" (under Use Embedded Thumbnail option) I can obtain the larger thumbnails. Not sure of the impact on cache and performance yet, but one issue at a time!
Thanks again.
Brett
Thanks again.
Brett
