Mouse wheel function corrupted after restart (reproduceable)
vladivostok
Post by vladivostok »
- Set "only one instance of XNView" in options.
- Make sure there is any function for mouse wheel (for example browsing through photos or going through thumbnails)
- Now you minimize the XNView
- Now you maximize/restart XNView by clicking shortcut on desktop or actual exe.
Now you will realize that any mouse wheel functions will be DEAD!
Tested on 1.95 b2, but also should apply to previous versions.
Anybody could confirm it?
Re: Mouse wheel function corrupted after restart (reproducea
If you don't have "only one instance of XNView", no problem?
vladivostok
xnview wrote:If you don't have "only one instance of XNView", no problem?
yes, you absolutely right! "one instance" is premise!
I can't reproduce
vladivostok
I can't reproduce
Hmm, test it in Viewer mode. In "keyboard /mouse" set mouse wheel to "previous/next file".
Now minimize XN to taskbar.
After you click on shortcut, XNView window will then maximize again (no new instance). If you then try to go with mouse wheel through photos, it will no more work!
Add.: It will only work again if you first press right mouse button. But immediately or after clicking with left mouse button, the mouse wheel function will not work again.
Ok, now i can reproduce
