1.95: Creating strip images: Wrong placement of lines
Peter2
Post by Peter2 »
A bug, already existing in older versions:
I you create a "strip of images" with images of different height, the calculation of the next line of images is wrong: XnView takes the height of the smallest images, add the line difference and sets the beginning of the next line. The result is that the next line covers the previous line - except the picture which is the smallest. There is a correct distance.
See here:
http://img504.imageshack.us/img504/2020 ... ionyc8.png
(I took one image, copy it to image1, image2, ....; cut the height of one image and made a strip).
You can see that the last line and the line before is no red horizontal line because the last line is too high and covers the previous line - except the image where I cut the height.
Peter
Peter2
Post by Peter2 »
Not yet fixed in Beta3.
Peter
Is this problem resolved in 1.95 final?
Peter2
Post by Peter2 »
helmut wrote:Is this problem resolved in 1.95 final?
No - still exists in 1.95.4.
Peter
Re: 1.95: Creating strip images: Wrong placement of lines
Please try XnView 1.96 beta
