Effects:Color noise reduction
I use ХnView for a long and loke it very much. But sometimes I would like to work in LAB colorspace, mainly to aplly color noise reduction. I would be happy to see this option in future release.
Maybe---
• Maybe the function set in:
Filter Menu >> Effects >> Noise >> Reduce noise could help ?
- Or are you talking of another thingy ?
Re: Maybe---
If I'm not mistaken, ik is referring to a (chroma/color) noise reduction method which requires not only color space conversion from RGB to L*a*b* and back again, but also the ability to edit the individual channels separately (Meesoft ImageAnalyzer: Operations » Pixel format conversion » Split color planes.../Combine images...).Clo wrote:- Or are you talking of another thingy ?
- Dan Margulis
- Color, Contrast and L*a*b* (Part I)
- Photoshop Lab Color – The Canyon Conundrum
- Digital Grin Photography Forum
- KammaGamma: Lab Noise
- Graphics.com: Photoshop for Digital Photographers » Part 3 – Color and Noise
- Web Design Library: Photoshop Tutorials » Photo Editing
- Adorama Imaging Resource Center: 100 photography tips in 100 days » Day 94 – Reduce noise with LAB
- 2 Minute Photoshop Tricks Guide: Noise Reduction – Step by Step
- Digiretus: Removing color noise
- ATPM: Removing Moiré
- The Unsharp Mask: Moiré Removal in Photoshop
- John Aydelotte: Chroma Noise Reduction
- D'Lynn Waldron: Eliminating color ‘noise’ in digital photographs using Gaussian Blur with Fade in RGB, or using Lab Color
- PhotoCamel Forums: Removing Color Noise Without a Third-Party Utility: i.e. Noise Ninja, Neat Image
