display values when auto correcting
BabaG
Post by BabaG »
i noticed this in playing with auto-levels but i think it would
be useful for anything that has an 'auto' button.
when applying an auto correction, like auto-levels, it would be
very helpful to display the values that xnview is applying
to the image. that way, if it's something we like, we could use
those values in a batch process or in nconvert.
it would make xnview a helpful tool for deriving settings to be
used with either further xnview processing, or processing in
nconvert.
thanks,
BabaG
Troken
Post by Troken »
Are not the values of auto-levels and auto-contrast individual for each and every image? If so, the values of one image will not be good for the next - the next image will need its own auto-correction in order to give the best result.
If the images are very similar it might work?
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=36546#36546]Image correction[/url]) wrote:
geometra wrote:Hi Pierre:
Can you explain how do you apply auto levels transformation?
I know how Photoshop does it because it is explained at its help. They cut the histogram at the tails by 0.5% of the values previous to the expansion. Are you making any of this? It is important to me to know if I will loos some values if I apply auto-levels and how many.
Congratulations for your work!
Yes i cut histogram too
BabaG
Post by BabaG »
one of the things i do is to shoot timelapse images. for this type of work
i want to apply a single setting to all of the images in a sequence.
i pick a representative frame and derive settings from it. often times
the auto settings look very good and i'd like to apply them but don't
know what they are.
thanks,
BabaG
