Panasonic LX3 raw files (.RW2) - ISO displays as 0 in browser and preview mode.
XnView v1.95.3
Panasonic LX3 raw files - ISO displays as 0
Re: Panasonic LX3 raw files - ISO displays as 0
http://rapidshare.com/files/163418534/P1010033.RW2.htmlxnview wrote:Could you send me a sample?
12mb raw file
also - XnView does not consider .rw2 file extensions - please add this extension (.rw2) to the list of raw files to display in browser.
Ok, thanks, and i'll add rw2Anonymous wrote: also - XnView does not consider .rw2 file extensions - please add this extension (.rw2) to the list of raw files to display in browser.
Thank you... also (however I am not sure if it is a bug or feature) - therexnview wrote:Ok, thanks, and i'll add rw2Anonymous wrote: also - XnView does not consider .rw2 file extensions - please add this extension (.rw2) to the list of raw files to display in browser.
is a tag <Focal> to display effective 35mm focal length , it is not working either w/ RW2 files, while tag <Focal> is working... for example I can see that <Focal> displays "5.1" (5.1 mm @ wide angle which should be 24mm effective 35mm focal length), but <Focal> displays "" (empty string, instead of "24")... is it fixable ?
