cannot update install latest version1.95.3
keith
Post by keith »
it stops half way gives me , abort retry but ignore is not a recommended choice. this has happened at least six times.
concerned that if I delete my old version I may not get the new version or the old version back.
It seem odd that it does not simply overwrite it
any suggestions - thanks: keith
retired person
ckit
Post by ckit »
Exit ALL file managers first!
Open XnView, go into Options, uncheck "XnView Shell Extension"
Exit XnView
Download "XnView Full ZIP Package"
Extract all files in "XnView Full ZIP" in your current XnView folder.
