problem with Canon raw files .CR2
How to use XnView. Post your question or ask for help, here.
Moderators: helmut, Olivier_G, Dreamer, XnTriq, xnview
Postby zan1964 » Wed Dec 10, 2008 2:10 pm
Hi to everyone and thankyou very much to the developers.
I'm experiencing a problem with Canon raw files (.CR2) from a 350D (Rebel xi) camera: they appears completely GREEN indipendently from the size of the view and in thumbnails too. I've recently installed the 1.95.4 release of XnView and I'm sure with the previous versions I could see the raw files correctly. Have you any idea about how to solve this problem?
Thank you very much in advance,
Paolo
zan1964
Re: problem with Canon raw files .CR2
Postby xnview » Wed Dec 10, 2008 4:11 pm
Do you have changed option/Read/Camera raw?
Postby zan1964 » Wed Dec 10, 2008 6:43 pm
xnview wrote:Do you have changed option/Read/Camera raw?
Hi Pierre, thank you for your help.
In effect after changing Options/Read/Camera raw I can correctly see the pictures, however the thumbnails are still shown in green...
Paolo
zan1964
camera raw
Postby Geert » Sun Jan 04, 2009 8:51 pm
Had the same problem.
Changed to auto WB and the problem was solved.
Geert
Postby helmut » Mon Jan 05, 2009 8:36 am
zan1964 wrote:pictures, however the thumbnails are still shown in green...
Thumbnails are created once and cached. Perhaps the wrong green thumbnails are stored in the cache.
Rebuilding the thumbnails (View > Rebuild Thumbnails) might help. If it does help for one directory, you might want to clear the whole cache (Tools > Options | Browser > Thumbnails | Cache | Remove all).
Moderator
green raw pictures
Postby Geert » Tue Jan 06, 2009 1:54 pm
The pictures in the slide show are also green.
There must be a bug some where.
Geert
Re: green raw pictures
Postby xnview » Tue Jan 06, 2009 2:14 pm
Geert wrote:The pictures in the slide show are also green.
Even if you change the RAW setting?
green raw pictures
Postby Geert » Tue Jan 06, 2009 8:16 pm
I am not sure what to change in the Raw settings.
After I changed the WB to automatic The preview and the full screen view are OK exept in the slideshow. Here the pictures still apear green.
Thanks for the interest.
Geert Hilbrands
Next username: Hilbrands
Geert
Postby terryo » Wed Jan 07, 2009 1:29 am
same problem here with my Pentax PEF files :
In 1.95.4 version, the colors are bad (yellow) and the contrast is poor
With 1.95.3, it was ok (thumbnail, preview and view). In Options/Read/Camera RAW, the four boxes are unchecked, and Gamma: 0.600, Brightness: 0.800, Red/Blue scaling: 1.000
With 1.95.4, I try to check these boxes without solution (deleting cache between tests)
Thank you in advance Pierre
terryo
Postby xnview » Wed Jan 07, 2009 8:17 am
Could you send me a PEF sample?
Postby xnview » Fri Jan 09, 2009 10:53 am
Please try XnView 1.96 beta
Return to General Support
Who is online
Users browsing this forum: No registered users and 6 guests
