Suggestion> XnView Shell Ext. custom file size limit
ckit
Post by ckit »
The Shell Extension needs a customizable file size limit so that if a file is under 1Mb it gets previewed but if it's over 1Mb it does not.
Preset values should be 1Mb and 2Mb as well as a custom value input field.
Re: Suggestion -> XnView Shell Ext. custom file size limi
ckit wrote:The Shell Extension needs a customizable file size limit so that if a file is under 1Mb it gets previewed but if it's over 1Mb it does not.
Preset values should be 1Mb, 2Mb, 5Mb, 10Mb and unlimited as well as a custom value input field.
Why? Too long?
ckit
Post by ckit »
Yes, large files take too long to process...
Esp. 2 or 3Mb PDF files using Ghostscript.
I feel this needs to be addressed.
ckit
Post by ckit »
No support for PDF's through the Shell Extension has to go completely. It's way too much of a drag on system resources. If something isn't done soon, I'll use SageThumbs instead (a 10Mb PDF nearly locked my machine up)
ckit wrote:No support for PDF's through the Shell Extension has to go completely. It's way too much of a drag on system resources. If something isn't done soon, I'll use SageThumbs instead (a 10Mb PDF nearly locked my machine up)
I'll add an option for EPS/PDF preview
ckit
Post by ckit »
Thank you.
