the cache db is 50mb and has 1500 fragments.
Fragmented db files?!
obelisk
The db files are greatly fragmented. My cat db is 300kb but has 100 fragments
could you pre-allocate space for these to save such trouble?
Jaff
+1
It would be nice to have a prealocated space for cache db (1/2/4MB segments selectable somewhere in options)
Meanwhile defragment your HDD with some defrag prog like Defraggler (freeware)
You can defragment a single file if you want (see picture)
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
obelisk
Rebellious
solution
Use Sysinternals' "Contig" free utility, works on individual files, no need to defrag the whole partition.
http://technet.microsoft.com/en-us/sysi ... 97428.aspx
obelisk
Rebellious
You can run it automatically every day using Window's Task Scheduler. 100 fragments is OK, even if you pre-allocated space, your db data will likely not be contiguous.obelisk wrote:yes, and doesn't help.
cuz my DB fragments every few days into 100+ bits
I'm still catagorizing my images.
until I finish in a few months, it's all crap
