xnview crashing when using batch scan twice
faulgott
Post by faulgott »
i've just noticed xnview 1.95.4 and 1.96 beta2 crashes after using "scan to" right after a previous scan... but scanning multiple images works when using normal scan cmd.
any ideas :?:
OS: XP SP3 Pro x32 Scanner: HP PSC 1215
Re: xnview crashing when using batch scan twice
I've tried a scan and after a scan into, and no crash...
faulgott
Post by faulgott »
thanks for the feedback, bthats odd... maybe system or driver related. I'll try another system with this scanner and report in a few hours :idea:
Post by Guest »
sorry for the double post, but it seems to be a driver problem. Solved with new OS Installation, but WIA Option works not properly with 1.95.4 ...should generate a "scan x.jpg" but "top.bmp" comes out :shock:
whatever works now flawlessly *Thumbs Up*
