Converting AI images?
vladimir
Post by vladimir »
I'm trying to convert AI images into PNG using NConvert with Ghostscript but till now cudn't succeded :| .I have installed ghostscrpt but still AI is not readed by NConvert.
please give me some clue about how do i convrt AI images into PNG using NConvert & ghostscript.
Re: Converting AI images?
vladimir wrote:I'm trying to convert AI images into PNG using NConvert with Ghostscript but till now cudn't succeded :| .I have installed ghostscrpt but still AI is not readed by NConvert.
Ghostscript can't load all .ai format.
As Pierre has pointed out, your problem might be that your AI have a subformat which is not supported.
You should check with a Postscript sample file whether Ghostscript is installed properly and works together with XnView or not. Also make sure you have AFPL Ghostscript installed - see topic 'How to display vector formats? GhostScript!' for more infos.
