"Show information": separate for viewer/fullscreen
Birdman
Post by Birdman »
Hi Pierre,
would it be possible to decide separately for the viewer and for fullscreen whether or not the "information" will be displayed? I would like to display certain picture information in the viewer but not in fullscreen. Right now it is only possible to display the information in the viewer when the options checkbox for fullscreen is marked.
Dreamer
Re: "Show information": separate for viewer/fullsc
Post by Dreamer »
Birdman wrote:Right now it is only possible to display the information in the viewer when the options checkbox for fullscreen is marked.
Not really, you can toggle Information with the hotkey (i) anytime, in any mode - viewer, or fullscreen. It's also a workaround for your problem.
Dreamer
Birdman
Post by Birdman »
Hi Dreamer,
you made my day (night)! I was not aware that this will work in fullscreen as well. This is what I really needed. Thanks a lot!
Dreamer
Post by Dreamer »
You're welcome.
Dreamer
