XnView 1.96 RC1
Feedback and Comments on the new 1.96 Test version on Windows.
XnView 1.96 RC1
XnView 1.96 RC1 can be downloaded here
In this ZIP, there is no .ini!!!!
Please, report only new bugs...
I would like to release the 1.96 next week...
pic_viewer
Post by pic_viewer »
Pierre, I think several people are still waiting for the fix list of beta 4. Or did I miss that? And what are the changes in RC1?
Sorry no list, i've fixed some of bugs/problems from here:
http://newsgroup.xnview.com/viewforum.php?f=63
Thanks for the 1.96 Release Candidate, Pierre. Good to get a final 1.96, soon.
DOS386
Re: XnView 1.96 RC1
Post by DOS386 »
I have an old bug only: there is a very bloated libogg-2.0.2.dll (with built-in Theroa + Vorbis ? if it isn't broken then it's obsolete at least) there in but no OGG/OGV format in the menu !
Re: XnView 1.96 RC1
No problem??
obelisk
Post by obelisk »
A number of trivial or critical fixes missing
cmd_Resize still has no toolbar icon.
http://newsgroup.xnview.com/viewtopic.p ... highlight=
remember folder on 'back'
http://newsgroup.xnview.com/viewtopic.php?p=72109#72109
Fragmented db files?!
Can't hide .db files
error movie
also
still no copy cat to/from iptc? not going to be in this ver? :(
ckit
Post by ckit »
Thanks for the RC1 release, Pierre!
I would like to point out though, no one has had the chance to test the 64-bit version of XnView Shell Extension v2.6.0, I have to keep re-installing v2.5.2 (64-bit) over the top of v2.6.0 (32-bit) !
obelisk wrote:A number of trivial or critical fixes missing
error movie
also
I means problem from change log
bmezenga
Post by bmezenga »
xnview wrote:I means problem from change log
Change timestamp/EXIF (PEF)
Pentax Makernotes (Shutter Count)
