Standard programs are gone after deinstalling 1.95
Ralf Kerkhoff
Post by Ralf Kerkhoff »
I got a reproducable bug, when unintalling Version 1.95
Just done this because I wanted to install Version 1.95.
After uninstalling 1.59 in Vista's system control, all standard programs are gone.
The whole list is just empty.
It seems, that uninstalling deletes all entrys in the following registry key:
HKEY_LOcal_Machine
Software
RegisteredApplications
Fortunally I have ha system backup handy :-)
If tested it two times, each of the uninstall emptys the registered apps.
Cheers
Ralf
Re: Deinstallation of 1.59
Strange, someone with the same problem??
RegisteredApplications is not changed
ckv
Post by ckv »
xnview wrote:Strange, someone with the same problem??
I extracted the installer with Inno Setup Unpacker and looks like the Inno script has a bug...
Root: HKLM; Subkey: "Software\RegisteredApplications"; ValueName: "XnView"; ValueType: String; ValueData: "Software\XnView\Capabilities"; Flags: uninsdeletekey
Should be...
Root: HKLM; Subkey: "Software\RegisteredApplications"; ValueName: "XnView"; ValueType: String; ValueData: "Software\XnView\Capabilities"; Flags: uninsdeletevalue
ckit
Post by ckit »
If the EXE package gets updated, please let us know!
Should be...
So with 1.96, i change the setup
ckv
Re: Standard programs are gone after deinstalling 1.95
Post by ckv »
XnView standard english setup (XnView-win-en.exe) still has this problem.
I checked Inno script and noticed that the all the "default programs" related registry lines are twice in the script.
Root: HKLM; Subkey: "Software\XnView\Capabilities"; ValueName: "ApplicationDescription"; ValueType: String; ValueData: "XnView is a fast multi-format graphics browser, viewer, and converter. It reads more than 400 file formats."; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities"; ValueName: "ApplicationName"; ValueType: String; ValueData: "XnView for Windows"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".bmp"; ValueType: String; ValueData: "XnView.bmp"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".gif"; ValueType: String; ValueData: "XnView.gif"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".iff"; ValueType: String; ValueData: "XnView.iff"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".jpg"; ValueType: String; ValueData: "XnView.jpg"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".pcx"; ValueType: String; ValueData: "XnView.pcx"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".pic"; ValueType: String; ValueData: "XnView.pic"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".png"; ValueType: String; ValueData: "XnView.png"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".tga"; ValueType: String; ValueData: "XnView.tga"; Flags: uninsdeletekey
Root: HKLM; Subkey: "Software\XnView\Capabilities\FileAssociations"; ValueName: ".tif"; ValueType: String; ValueData: "XnView.tif"; Flags: uninsdeletekey
First there is the correct line with the uninsdeletevalue flag, then later in the script there is another line with uninsdeletekey flag. XnView standard english setup is the only setup with this problem.
ok, right
