Hi
When i open some pspimage files i get a error which says "Error Reading file" the files were created with psp X2
any ideas?? Thanks
problem opening some pspimage files
Re: problem opening some pspimage files
- Emeraldisle's Portal: Compatibility: Making images that will work in all forms of PSP
- PSPUG Message Board: .pspimage PSP 8 & PSP X2
- Tech Support Guy Forums: Problem opening in Psp 9 a file saved in Psp x2
- Michele's Paint Shop Newbie 101: PSP Calendar Tutorial » calendar-tutorial.zip
Thanks for the Info Xntrig I will give it a try looks like it will solve my problems.
