Screenshot with region of screen
qiuyingtao
I like XnView very much. And I hope its new version will contain the feature of catching screen in region.
Re: if it have a new feature...
Not sure yetqiuyingtao wrote:I like XnView very much. And I hope its new version will contain the feature of catching screen in region.
Re: Screenshot with region of screen
If you use screen capturing often, I recommend to look for a tool which really covers your needs. There are very good programs out there, some of them may cost some bucks but it's worth the money if you use it more often.qiuyingtao wrote:I like XnView very much. And I hope its new version will contain the feature of catching screen in region.
Some "advertisement":
Personally I've tried a bunch of tools, including HyperSnap, SnagIt, and many more. The one which was slim and covered my needs best was SmartCapture (http://www.desksoft.com). It's worth a trial, but not freeware.
I like MWSnap. Does everything I need and then some. Free.
http://www.mirekw.com/winfreeware/mwsnap.html
John
MWSnap is a very nice one, indeed. Small download size (644 Kb), capturing of rectangles, menus, ... And additional features like a ruler, adding a frame, magnifying glass when capturing, default sizes, multi-language. Very good.JohnFredC wrote:I like MWSnap. Does everything I need and then some. Free.
Thank you for pointing to that one, John!
