About slideshow
andrea.ippo
About slideshow
Post by andrea.ippo »
Is it possible to start a slideshow from the Browser with all the images in the current folder?
The firse time, I am asked whether to use the selected images or the checked ones. I would like to make a slideshow of all the images in the folder I'm in.
Is this possible?
I think it would be a lot easier to use slideshows if you could skipping the selection / checkmarking of all the files, if you want to see them all in the slideshow.
Thanks
marsh
Re: About slideshow
Post by marsh »
andrea.ippo wrote:Is it possible to start a slideshow from the Browser with all the images in the current folder?
Is this possible?
Thanks
The following option will select all photos in current folder:
Options>General>Misc>SlideShow [Use all images in current folder]
To use: Select/highlight/tag nothing in file list, then press <ctrl +l>
andrea.ippo
Re: About slideshow
Ok I've found the answer I was looking for in the user guide:
If you frequently make slide shows consisting of ALL the files in a particular directory and/or its sub-directories, to to Options > General > Misc. and find look at the slide show option for automatic selection of files.
andrea.ippo
Re: About slideshow
Is this possible?
Thanks
Oops we've posted in the same moment.
Thank you
marsh
Re: About slideshow
Post by marsh »
Is this possible?
Thanks
Thank you
That should bring good luck. Or a new version. :)
