Many thanks for a soon answer!
Picture-Name from the camera
rolben
Is in XnView a possibility to get the picturename from the camera in WIA-Mode?
Re: Picture-Name from the camera
On some camera, original filename can't be retrieve...rolben wrote:Is in XnView a possibility to get the picturename from the camera in WIA-Mode?![]()
rolben
How I can retrieve? In WIA-Mode I have to enter a filename and startnumber and the number to add. how can I ignore these parameters?
Where?? Could you post a screenshot?rolben wrote:How I can retrieve? In WIA-Mode I have to enter a filename and startnumber and the number to add. how can I ignore these parameters?
rolben
Now here are the two pictures from Xnview. It's in the file-menue - "read from scanner or camera (WIA)".
rolben
The first try with the images failed because I used the wrong filename.
Yes, because on some camera, i have problem to retrieve original filenamerolben wrote:The first try with the images failed because I used the wrong filename.
