Silent Deployment of XnView
Hello I like to deploy XnView without any user clicks. I know the switch "/silent", but I like to know how I can set the .bmp link with XnView per BATCH or Switch.
Re: Silent deployment of XnView
There might be other and more professional ways to do a silent installation of XnView (e.g. Software Management tools, ...), but I followed your initial idea and tried it out. What you need is a small batch script and a .reg file containing registry keys exported from regedit.
The batch file will
- call the XnView setup program in silent mode
The .reg file contains the keys for the file associations for the .bmp format.
File "xnview-install-silent.bat":
File "xnview-assoc.reg":
The registry keys above are exported using RegEdit on Windows 98. The format of the .reg file might differ when using RegEdit on newer Windows platforms.
The batch file will
@echo off
regedit /s xnview-assoc.reg
XnView-win1.66-full-de.exe /silent
REGEDIT4
[HKEY_CLASSES_ROOT\.bmp]
@="XnView.Image"
[HKEY_CLASSES_ROOT\XnView.bmp]
[HKEY_CLASSES_ROOT\XnView.bmp\shell]
[HKEY_CLASSES_ROOT\XnView.bmp\shell\open]
[HKEY_CLASSES_ROOT\XnView.bmp\shell\open\command]
@="\"C:\\PROGRAMME\\XNVIEW1.66\\XNVIEW.EXE\" \"%1\""
[HKEY_CLASSES_ROOT\XnView.bmp\DefaultIcon]
@="C:\\PROGRAMME\\XNVIEW1.66\\XNVIEW.EXE,2"
more:
File 'associate.reg'
I use this batch file:
May be someone help.
Windows Registry Editor Version 5.00
@="XnView.bmp"
"PerceivedType"="image"
"Content Type"="image/bmp"
[HKEY_CLASSES_ROOT\.emf]
@="XnView.Image"
[HKEY_CLASSES_ROOT\.gif]
@="XnView.gif"
"Content Type"="image/gif"
[HKEY_CLASSES_ROOT\.jpe]
@="XnView.Image"
"Content Type"="image/jpeg"
[HKEY_CLASSES_ROOT\.jpeg]
@="XnView.Image"
[HKEY_CLASSES_ROOT\.jpg]
@="XnView.jpg"
[HKEY_CLASSES_ROOT\.png]
@="XnView.png"
"Content Type"="image/png"
[HKEY_CLASSES_ROOT\.rle]
@="XnView.Image"
[HKEY_CLASSES_ROOT\.targa]
@="XnView.Image"
[HKEY_CLASSES_ROOT\.tga]
@="XnView.tga"
[HKEY_CLASSES_ROOT\.tif]
"Content Type"="image/tiff"
@="XnView.tif"
[HKEY_CLASSES_ROOT\.tiff]
@="XnView.Image"
[HKEY_CLASSES_ROOT\.wmf]
@="XnView.Image"
@="C:\\Program Files\\XnView\\xnview.exe,2"
@="\"C:\\Program Files\\XnView\\xnview.exe\" \"%1\""
[HKEY_CLASSES_ROOT\XnView.gif]
[HKEY_CLASSES_ROOT\XnView.gif\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,3"
[HKEY_CLASSES_ROOT\XnView.gif\shell]
[HKEY_CLASSES_ROOT\XnView.gif\shell\open]
[HKEY_CLASSES_ROOT\XnView.gif\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.iff]
[HKEY_CLASSES_ROOT\XnView.iff\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,4"
[HKEY_CLASSES_ROOT\XnView.iff\shell]
[HKEY_CLASSES_ROOT\XnView.iff\shell\open]
[HKEY_CLASSES_ROOT\XnView.iff\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.Image]
@="XnView Image"
[HKEY_CLASSES_ROOT\XnView.Image\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,1"
[HKEY_CLASSES_ROOT\XnView.Image\shell]
[HKEY_CLASSES_ROOT\XnView.Image\shell\open]
[HKEY_CLASSES_ROOT\XnView.Image\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.jpg]
[HKEY_CLASSES_ROOT\XnView.jpg\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,5"
[HKEY_CLASSES_ROOT\XnView.jpg\shell]
[HKEY_CLASSES_ROOT\XnView.jpg\shell\open]
[HKEY_CLASSES_ROOT\XnView.jpg\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.pcx]
[HKEY_CLASSES_ROOT\XnView.pcx\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,6"
[HKEY_CLASSES_ROOT\XnView.pcx\shell]
[HKEY_CLASSES_ROOT\XnView.pcx\shell\open]
[HKEY_CLASSES_ROOT\XnView.pcx\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.pic]
[HKEY_CLASSES_ROOT\XnView.pic\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,7"
[HKEY_CLASSES_ROOT\XnView.pic\shell]
[HKEY_CLASSES_ROOT\XnView.pic\shell\open]
[HKEY_CLASSES_ROOT\XnView.pic\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.png]
[HKEY_CLASSES_ROOT\XnView.png\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,8"
[HKEY_CLASSES_ROOT\XnView.png\shell]
[HKEY_CLASSES_ROOT\XnView.png\shell\open]
[HKEY_CLASSES_ROOT\XnView.png\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.Slide]
@="XnView Slide"
[HKEY_CLASSES_ROOT\XnView.Slide\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,0"
[HKEY_CLASSES_ROOT\XnView.Slide\shell]
[HKEY_CLASSES_ROOT\XnView.Slide\shell\open]
[HKEY_CLASSES_ROOT\XnView.Slide\shell\open\command]
@="\"C:\\Program Files\\XnView\\xnview.exe\" -slide \"%1\""
[HKEY_CLASSES_ROOT\XnView.tga]
[HKEY_CLASSES_ROOT\XnView.tga\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,9"
[HKEY_CLASSES_ROOT\XnView.tga\shell]
[HKEY_CLASSES_ROOT\XnView.tga\shell\open]
[HKEY_CLASSES_ROOT\XnView.tga\shell\open\command]
[HKEY_CLASSES_ROOT\XnView.tif]
[HKEY_CLASSES_ROOT\XnView.tif\DefaultIcon]
@="C:\\Program Files\\XnView\\xnview.exe,10"
[HKEY_CLASSES_ROOT\XnView.tif\shell]
[HKEY_CLASSES_ROOT\XnView.tif\shell\open]
[HKEY_CLASSES_ROOT\XnView.tif\shell\open\command]
[HKEY_CLASSES_ROOT\Applications\xnview.exe]
[HKEY_CLASSES_ROOT\Applications\xnview.exe\shell]
[HKEY_CLASSES_ROOT\Applications\xnview.exe\shell\open]
[HKEY_CLASSES_ROOT\Applications\xnview.exe\shell\open\command]
XnView-win-full.exe /silent
copy /b /Y xnview.ini %programfiles%\xnview\
regedit /S associate.reg
SniCKerZ
